460 cam shaft
Old 08-06-2013, 11:02 AM
Chris Guthro's Avatar
Chris Guthro
Chris Guthro is offline
460 cam shaft
I need to know if this camshaft is way to radical for my engine. First off its a 1978 Lincoln 460. Its stock so far other than the 1970 straight up timing chain ive bought to put in it so far. Ill be adding long tube headers and hopefully a weiand stealth intake and maybe a bigger carb. the guy has it brand new in the box and will sell it for 100 bucks as its to small for his 800 horse 545. he said the card has 595 deg intake and 621 exhaust. With those future mods is this cam to big without doing anything to the heads? its going in a 84 f150 2wd with c6 and 9 inch limited slip.
BIG BLOCK V-8 CAMSHAFT 385 SERIES (429/460) | Part Details for M-6250-C460* | Ford Racing Performance Parts
Old 08-06-2013, 11:09 AM
Chris Guthro
what would be a good one?
Old 08-06-2013, 02:28 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
That cam going to work with the low compression in your stock '78?
I can't find Ford Racing 460 crate engines anymore. They say they use that cam in M-6007-C460, but I can't find that engine on their site.
I did find this, check post 3:
What does these # tell me M-6007-C460 - 460 Ford Forum
If that cam was used by Ford in an 11:1 crate motor, I would guess it will be a complete pooch in an 8:1 motor.
You would probably have to swap springs and possibly other work as well, as the stock '78 springs would probably coil bind with the extra lift.
Best do your rebuild all at once. A part here, a part there and you'll go broke buying gaskets along with not getting much for your efforts.
Old 08-09-2013, 08:36 PM
mark a.'s Avatar
mark a.
mark a. is offline
It is WAY too big.
xirxious
09-01-2019 07:30 PM
69wannabe
08-30-2017 05:13 AM
twwtruck
02-24-2013 04:13 PM
theguy_88
02-23-2006 12:06 PM
sailfrog1
06-08-2005 05:49 PM
Quick Reply: 460 cam shaft
