Accelerator Linkage for a 67 250 352
BRB....
On the way back home, I went and bought a new LED computer monitor.. ahhh.. MUCH better!
Below is the pic of my 70. I have moved the breather hose out of the way for a clearer shot. The 2100 carb and intake will eventually go away fto make way for an Edelbrock intake and FAST EFI....
The rod and clips are from my 68 Mustang.' had to put a mild bend to correct the angle. There are other options on the market - 1) first is a billet rod with heim joints.. about $60; and 2) Head to your local hardware store and pick up some steel rod and a couple of small heim joints. Cut the rod to length, cut some threads for the heim joints, assemble, and bolt it on... about $15.
Stock:
Or a $12.95 kit:1964-1973 MUSTANG PARTS / MUSTANG ENGINE / MUSTANG CARBURETORS, LINKAGE & SPACERS / MUSTANG CARBURETOR LINKAGE -- Sacramento Mustang Online Store
Stock:
I took that squirel cage completely off and used the single adjustable rod from a 70's truck and bolted on a ball stud to the carb from a holley. Couldn't be more simple and no bushings to wear out.
I get what you mean by keeping it stock but you would also be using a genuine ford truck part by using either of the solutions posted here!
Thanks, I appreciate the help you can find on the forums. My son and I are just about finished with the Mechanical reconditioning, this was the last item to take care of. The '67 Camper Special is at the Body Shop getting a really nice make over and will be ready for my son on his 16th Birthday. I was kinda hoping he would take my 2000 Ford F150 and let me keep this one.
Great, simple solution. Makes you wonder why Ford used the old trapeze setup anyway? Lookin at that stock pic...what is the other rod that looks like it runs into the cab? I should know this, I know my truck has one, but can't remember what it is or what it does or what it connects to.
The original set-up has too many moving parts and why I simplified it.
throttle linkage
Sir, I have a 68 f100 that was originally a standard shift, without the stabilizing linkage it is very hard to drive as the throttle will pull itself open when you let out the clutch,I almost wrecked my truck when I changed it to a 4 barrel and was in a hurry to try it out,needless to say I found out the hard way what it was for. The next day I made new rods .I now have a c6 in it and still have the original linkage on it. With a automatic it is not as critical.Kenny Nunez
