Coolant Crossover Tube/Intake Manifold leak and replacement
My wifes 2000 Expy just a sprung a coolant LEAK! It's leaking at the passenger side valve cover/right out of the metal crossover where it joins with the intake.
I have researched and found that the '97-99 used and entire aluminum intake and then Ford revised their "composite" Plastic intake after 2003. I also found I have to completely REMOVE the intake and replace it as a WHOLE assembly..??? Ford??? Seriously??? I love Ford's but this Triton motor is becoming my last Ford product I ever touch.
Ranting over..Still irritated...
I found a complete '97-99 aluminum intake for the 5.4 on Ebay and want to know if I can purchase it in place of the Composite intake. I have heard and from what I was looking, Aluminum is getting hard to find.
cross over leak
i have been dreading this on my '98. Please post back when done and let us know what you did to fix.
thanks
There is a coolant tube that runs under the intake, be sure to inspect that. There is also a coolant connection between the upper and lower intakes where the o-ring tends to fail. Lastly, I would change the spark plugs while the intake is out. They are much easier to access without the intake there.
I found a "chunk" of hard plastic in the thermostat housing. I'm gonna try to post pics of it and the leak so it may help others.
The Expedition has 201,XXX miles and have no idea about when plugs were last changed. Do I need to order the tool for broken spark plugs before attempting to remove them. I have time so its not like it gonna be down because I break one, but want to be prepared for the worst.
Thanks again for your timely replies Alloro.
Update: Just popped out #5, it's an AutoLite. Looked rather well, showing about .067 gap.
I had let the plugs sit over night in a PB Blaster/Liquid Wrench Formula, to aid in removing. Took less than a minute to remove it, but I'm sure that #3 and #4 will be totally different.
Also is it worth removing the valve covers, and buying the tool to check the rocker arms and the lash adjusters? I could use new valve covers gaskets, but the wifey isn't happy that she doesn't have a vehicle anymore either...
IMO, the plugs last 100K miles, so go with the Motorcraft ones and then forget about them. Using other brands could cut into the 100K replacement milestone and force you to have to replace them sooner.
Also, I would only remove the valve covers if they're leaking oil or the valve train is making noise. Otherwise, you could end up doing extra work for nothing while pissing off the wife in the process.
According to the workshop manual, spark plug torque specs are any of the following that you prefer to use:
78-176 in. lbs.
9-20 Nm
6.5-14.67 ft. lbs.
I like to use 13 ft. lbs. because that's what is shows on the actual procedure page in the workshop manual, which I've attached as a PDF.
