Another Battery post !!!
LOL..
well yesterday.. my truck almost didn't start.
I drove it for a few miles and it started fine the rest of the day.
well this afternoon it almost didn't start again after sitting over night. it turned over Very slow and just started before the starter stopped turning..
The truck ran bad until the battery's charged back up.
I knew last year, under a load test they were only about 70%.
So, What is your guys suggestions on battery's for these trucks ?
Cranking amps ?
Motorcraft or other ?
thx Phil
Cranking amps ?
thx Phil
Received 3,110 Likes
on
Check the water level, too. I noticed my two year old batteries seemed to be cranking the truck a little slower than normal. Bought some distilled water, topped off all 12 cells (6 per battery) and after a couple drives, it cranks more normal.
(The advantage of driving a rental car the last four weeks while my wife has been driving the truck for the most part - everything sounds new or different).
Do not use OPTIMA, they are junk. I had two yellow tops go bad in my excursion within 2 years of manufacture date. They do not hold up in diesels due to the vibration of the motor. They are not the quality they used to be, made in Mexico now. I have two Kirkland batteries in mine now and it seems to start smoother. Die-hard platinum's are good as well as interstate. I would go with Auto-zoo or a large chain so replacement is hassle free. Pretty much every town has either an AZ or Advance Auto Parts.
Duralast
I have a couple of Duralast Golds from AZ. 3 year free replacement and like Kdr358 said there is an Azone every where. Had them checked a couple of days ago because i was having sluggish start problems. They wanted to test with the little hand held tester but I had them put them on the full load tester to make sure they weren't breaking down under a load. Both tested 100% and they are 2 years old. Turns out my starter was shot. Sure acted like weak batteries as it would turn over slow till cranking. Spins right up with the new one.
Do keep in mind there is not a problem with the electrical system in my truck either.
I'm running interstates now and haven't had them long but so far so good. You want at least 850 cca I believe it is. I have an 8 year warantee I think it is... That in itself is worth it to me.
Alt is good. I have had the truck now for 7 years now. It was a used 02 truck with 50K when i bought it. I have never touched the battery's. I did a load test at the beginning of last year and they were at about 72%. I had to replace the alt at that time because it went bad. First morning start is and very slow and after i drive it, it will spin the starter fine and fast the rest of the day.. So i guess im going to costco
