Flowmaster Super 10 vs Cherrybomb Extreme?
Hey guys just need a little advice on exhaust for my 94 Lightning. Recently I've had a baffle in the muffler break loose and it is making a horrid squeaking noise, driving me bat***** crazy. So its time to replace them. I want to go a bit louder and deeper, so I'm kinda up in the air between Flowmaster Super 10s or Cherrybomb Extremes. Is one better than the other for any reason or is there something else similar I should consider?
My current set up is Hooker long tubes, Bassani 2.5in off-road y-pipe, Flowmaster classic 40s, 2.25in stock tailpipes.
Any advice is greatly appreciated!
It already is dual. Bassani calls this mid pipe a y-pipe, but its an x. I actually already ordered some super 10s. I met a guy with 351w bronco with them and it sounds wicked! I did look at the 44s though, but the shop im going through has to special order those and they are considerably more expensive than the 10s. Either way I'm getting the 10s installed tomorrow, I'll post a vid so you guys can check it out.
