F250 Master Cylinder swap
Years ago my friend had a 82 F150 we put a larger F350 MasterCylinder on it(we had it on hand) Only thing it did was make the brakes very touchy and more of a issue than worth(shattered a pad on front due to higher brake pressures). After getting the correct MC and new pads it's all fine.
Bigger is better, but not in this case unless you switch out the entire braking system to the larger one.
jenkinsj
09-04-2005 04:12 AM
Katmandu2
08-14-2003 05:07 AM
