Rear A/C Issues
Rear A/C Issues
2005 Expedition.
Look through some searches with no luck, so here's my issue. A year ago, my rear air was making the well know "thumping" noise when it was turned on. It still functioned, just with the noise. 2 months ago, the rear air would only blow out of the bottom rear vent, and no longer the ceiling. In my messing with the ac, it suddenly stopped working all together in the rear. Both heat and ac. I change the rear actuator gear assembly in the back fender well and it had a worn out part (gears all chewed up). But I still have the issue that the unit will not turn on. Again, the rear air. I checked the applicable fuses, with no luck. Am I missing something else?
surfwagon
05-18-2018 05:02 AM
elo179
10-30-2012 01:19 PM
