Transmission Cooler, Lines, and Filter upgrade
So my tranny front seal leak was due to a overheat, I filled it up with fluid today, ran fine with no leaks. So the big ol' Ford is on the road again.
Now I'm going to upgrade my transmission cooler, lines, and filters.
this is the aux cooler I am looking at:
Ford Aux Tranmisson Cooler 310-900-3000
It comes with a e-fan that is tstat controlled so it only starts cooling the tranny when it needs to.
This is the external filter kit I am looking at:
External Transmission Filter Kit
Now I just need to find a snap ring kit for the filter, and a temp gauge.
Any suggestions?
Any suggestions?
That cooler is nice, but unless you plan to spend a lot of time pulling HUGE loads or it gets REALLY hot where you live, it is a little much.
As for the filter, from personal experience, stay away. I put one in when I did my trans service and it failed within 500 miles. It sprayed about 4 quarts of fluid ALL over the front end of my truck and my engine. Switched over to this for about $30.
squaredancer
11-16-2012 08:34 AM
