Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
08 Escape hybrid drain coolant plug
Old 07-15-2013, 04:34 PM
Avanti's Avatar
Avanti
Avanti is offline
Does 08 hybrid have a block coolant drain plug? I know the radiator does. The factory shop manual says to make sure coolant drain plugs if equipped are tight????
Old 07-15-2013, 05:49 PM
wptski's Avatar
wptski
wptski is offline
Really doesn't matter as you would have had a problem by now.
Old 07-15-2013, 06:36 PM
Avanti's Avatar
Avanti
Avanti is offline
Hybrid coolant plug
I need to know where it is so can drain the old coolant & put in new.
Old 07-16-2013, 01:37 PM
wptski's Avatar
wptski
wptski is offline
The block drain plug on the Hybrid isn't even mentioned in the '09 Ford Workshop Manual probably because they use a Radiator Refiller Tool. You must bleed the air from the system also and it just mentions that being needed but no other info. I know the Owner's Manual gives the location of the bleeder valve. You add coolant till it comes out from at the valve while open.
menzfamfour
1997 - 2003 F150
04-21-2016 08:30 PM
dwh039
6.2L V8
01-28-2016 09:12 AM
Lushman
33
08-16-2006 07:52 AM
irvinf
1983 - 2012 Ranger & B-Series
02-12-2004 02:48 PM
Bob P
09-27-1999 02:59 PM
Quick Reply: 08 Escape hybrid drain coolant plug
