The dreaded Door Ajar light....
The "Door Ajar" light on my Ex has apparently decided that I would enjoy having the little red light on the dash illuminated. Normally, I'd consider this just a nuisance, but it's convinced the interior and running board lights to play along so that they don't go out until they time out.
I'm pretty sure that it's in the rear door somewhere. Does anyone know where the sensor(s) are for the rear doors and how to test them?
Thanks,
~Bass
Thanks,
~Bass
It's been covered fairly well here but check and lube all your door and hatch latches. Check all your weather stripping make sure it isnt creating a gap somewhere. Also clean and check all the rubber around the plungers/sensors. Grit and dirt will accumulate on those barn door sensors.
Mine seems to occur after a bunch of dusty trail riding. Not everytime though. I usually have to clean and lube all the latches and slam the doors a few times and it goes away for a while.
Take apart the mechanism in the hatch. Clean everything well, use WD or equivalent to lube the switches and clean/lube the handle mechanism while you're there too.
The switches are located at the latches on the outer bottom corners of the hatch. Its not a fun job but once done, it works like new and the ajar thing is done for a long time.
I could be wrong, but I don't think cutting them is the fix. My passenger side hatch switch was unrepairable, so I just unhooked the wiring harness from it and jammed a paperclip in it to short the two wires together and wrapped it all up in electrical tape. The driver side switch still works to show when the hatch is open or closed.
Just because I feel like grumbling, this job is going to take longer than I thought.
Removed both of the latches from the rear window and tested the switches with a circuit tester. Both work as expected. Then the rains came.
So. Two switches per afternoon. Worst case is a week to figure this out...
You might just have tested them when they felt like they did want to work...
Are you going to clean them or replace them ?
