1965 F100 vin decode need help
F10DR639058
I THINK..
F10 F100
D 292 Engine
R San Jose, CA Assembly Plant
639058 Serial Number
129" Wheel Base
Rangoon Red (J) and Wimbledon White (M) Color Theme
Automatic Transmission
I'm sure those with more knowledge than me will correct any mistakes or add more information.
Google is my friend..
I THINK..
F10 F100
D 292 Engine
129" Wheel Base
F10 = F100 2WD truck
D= 352 8 cyl engine
R = San Jose, Ca assy plant
639XXX = April 65 build date... Im away fromhome so thats an educated guess
JM = Rangoon Red & Wimbledon White exterior paint
129 = wheelbase
F100 = model = 5000# gvwr
G -= transmission = Cruise-O-Matic
08= rear axle ratio = 3.50 as I recall, non locking axle
There is a DSO number too..either 2 or 6 digits... The first 2 are where the original selling dealer ordered the truck from
71= Los Angeles
72= San Jose
73= Salt Lake City
74= Seattle
75= Denver
D= 352 8 cyl engine
129 = wheelbase
71= Los Angeles
72= San Jose
73= Salt Lake City
74= Seattle
75= Denver
Originally Posted by westcoast4121
VIN: F10DR639058 / BODY: E81 / TRANS: G / AXLE: 08 / MAX GVW LBS: 5000 / CERT. NET HP: 172 / RPM: 4000 / DSO:
E81: E = Red Crush Vinyl & Red Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
G = MX Cruise-O-Matic.
08 = Ford 9" Rear Axle / 3.50-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
Engine code D: 1961/64 F100/700 292 4V / 1965 F100/350 352 / 1966/78 F500/750 330 2V H/D FT engine.
Engine code Y: 1966/67 F100/350 352 / 1968/76 F100/350 360.
flypfi
23
10-21-2014 03:36 PM
69supercj
05-14-2010 09:20 PM
