Side or rear exhaust
Is this for a pic-up or panel? A panel needs it out the sides because of the "station wagon effect". A Pic-up really doesn't care. The fumes aren't going to roll in the back door seams like a Panel would.
The sound however tends to be mellower coming out the back due to the longer pipes compared to the side dump method. The side dumps also tend to emphasis the sound of only half your cylinders compared to the stereo effect of routing them out the back.
Listen to a few of each and see what I mean. Also, pay attention to the diameter of the pipe used. The larger the pipe....the deeper the tone. The type of muffler used will effect the tone as well.
Hope these pointers help ya out at least a little bit.
Capt'n
Capt'n
I went all the way out to the back. Here's a few pics:
This shows the glass packs and the crossover tube:
Here's the back before I mounted the back bumper. Keep in mind that I had an idea of the bumper dimensions so we set up the tailpipes to clear the future bumper:
Here's the look with the bumper installed...you don't see much of the pipes:
Mine is out the side, but having owned so many vehicles with side pipes in the past I knew that it was going to be loud and would sound like a 4 cylinder out each side. This time I went with an X-pipe to mellow the tone and change the 4 cylinder sound.
I recently did a quick redneck wire job and fired it up. Definitely doesn't have the 4 cylinder sound out each side, but the jury is still out on how loud it's going to be once it's pulled out of the confined area of the garage.
I must say I'm amazed at how different the sbc sounds running with the X pipe.
Properly done they smooth out the "pulsing" of the exhaust notes from the two cylinder banks and aid in scavenging. This increases torque and horsepower, particularly at given points in the power band. Improperly done and they have the potential to be a waste of money at best. The hot rod magazines used to say that one could use standard Krylon paint on a dual exhaust and where the paint quit burning was where you put the crossover pipe (H-type) for best scavenging. The proper calculation of exhaust designs is, actually, rocket science.
JosieGallows
32
01-28-2016 08:43 AM
brad1979
63
09-02-2012 06:53 PM
hwyhogg
21
01-07-2011 08:45 AM
