1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F350 auxiliary fuel port question
Old 07-06-2013, 12:06 AM
ksfirefighter's Avatar
ksfirefighter
ksfirefighter is offline
Building a brush truck and have a new F350 supercab with a short bed takeoff. I understand that if we had bought a cab and chassis the fuel tank would have the aux. fuel port in it.
Well we wanted the short wheel base so we did a bed takeoff. Now I need to figure out how to supply fuel from the truck to the pump motor. Is there a way to change the lines on the tank to do this or maybe buy a new fuel pump with the aux port on it. Its a gas truck with the mid mount fuel tank.
any help would be greatly appreciated!!!
Old 07-06-2013, 09:12 AM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
Old 07-06-2013, 08:01 PM
ksfirefighter
that may be just what we need. Hopefully we can use the FDM for the 40 gallon tank on the tank we have. Thank you for the link!
Old 07-07-2013, 07:41 AM
Thenewboss's Avatar
Thenewboss
Thenewboss is offline
We went a different direction with our Brush Truck. We got a F350 XL, LB, CC, PSD, and the pump, water tank, and hose reel all fit in the long bed. The only problem I have with it is that the pump only has a two gallon tank so it runs out of gas pretty quick. I imagine if we had gotten a diesel pump we could have tapped into the trucks fuel and then all we would have to worry about is running out of water, we have a 250 gallon tank I think. Good luck with your project!
kd2dwj
2017+ Super Duty
18
02-06-2022 09:51 AM
90pioneer
6.7L Power Stroke Diesel
10-23-2015 02:56 PM
MadCowRacer
11-17-2010 08:01 AM
Ford_F-250_1990
06-04-2007 08:38 AM
peppy
19
01-04-2004 08:43 PM
Quick Reply: F350 auxiliary fuel port question
