Airbag Light
Airbag Light
The Airbag light on my 99 Ford Ranger has started flashing recently. It flashes code 27 which I was told meant the passenger airbag on/off light was burned out. I've also read that I will have to replace the entire module since the LED is soldered onto the module.
I was quoted a price of $35 at a local junkyard.
Now, I haven't pulled the module off to look at it but what I was wondering is if the key cynlider is connected to the module or if it is seperate. I don't want to spend $35 and then have to have the cylinder re-keyed or carry two seperate keys with me.
Airbag Light
The switch itself is seperate from the module. There is an electrical connector on the switch which you will need to unplug.
P. S. Before replacing the module, make sure you take off both battery cables (negative first) and wait at least 2 minutes for the ABS power supply backup to be depleted.
Let us know how it turns out.
Airbag Light
Glad to hear that you fixed the problem . I'm not quite sure I follow you though on the part about the module and switch being the same component. Maybe it's different for the '99s I don't know, but the switch on my '98 has an electrical connection that I can see when I remove the ashtray. And my Ford Manual says the switch is a seperate and removable piece.
Airbag Light
First of all, this is an excellent forum. Thanks for the helpful info.
I am getting the same airbag light code on my 1999 Ford Ranger XLT. The on/off light in my airbag control module is out so I assume this is the problem.
Is it safe to assume that the airbags still work even though the on/off light is burned out?
