dp infinity fuel pressure set up #2
i've been going back and forth with the user manual for the last 20 minutes and I feel like I need a zanax now. If anyone has set one of these up can you give me a heads up as to what page I should be on?
https://www.dp-tuner.com/index.php/a...itfile_id/222/
I figure I'm supposed to be on page 20 in the manual.?
And in the "analog c" screen in the infinity.
Then there is this on pg 20 which is what I assume I need to do to get a signal.?
To change the level of parameters you will search for on an enhanced driver:
1.
Make sure the enhanced driver is installed in the Device Manager, and a “Find Signals” procedure has been performed once.
2.
From the Main Menu tap on [Setup], then [Devices],then [Parameters].
3.
Use the [<] or [>] buttons at the top to find yourenhanced driver.
4.
Tap on [Complete Signal List] to highlight and tap[Change].
5.
Enter a 1 or a 2 on the number pad.
6.
Tap [Save], then [Exit].
7.
Run “Find Signals’ one more time to search the expanded list.
You will now be able to select and assign the new data in your gauges.
In #1 where it says make sure a find signals procedure has been performed. Is line #2 the find signals procedure? And in #5 where it says to enter a 1 or 2. Does it literally not matter if I enter a 1 or 2?
Thanks
1.
2.
3.
4.
5.
6.
7.
Thanks
Hi Mike,
Are you just trying to get the fuel pressure sensor setup? If so, there is no need to do anything with the drivers or install a new one. The analog(b and c) are already setup and ready to go when you get the device. All you have to do is modify the one that you have the fuel pressure sensor hooked up to(the other one will already be EGT).
Do do this, start from the main menu. Click Setup, then Devices, then Parameters, then scroll over to the analog input for your fuel pressure sensor. Click on the category(ex. correction factor, correction offset, etc.) that you want to modify and then click Change(on the bottom of the screen). Modify the values and then click Exit when you are done.
It should be ready to go at that point.
amgpro2
07-30-2010 07:23 PM
