Shop price for bullet-proofing 6.0 worth it?
My HPOP died over the weekend, got truck towed to shop. They quote 8 hours at $82/hour plus parts a sum of about $1500 to replace HPOP. I figure if they are pulling stuff off the top of the motor, maybe I can go ahead and do an EGR delete, oil cooler, and head studs while they are at it, so I ask for an estimate of such. they respond with 25 hours total and parts list/prices attached. Is this realistically worth it? Way overpriced?
What you guys think?
I know I can source a lot of these parts on my own and save a penny, but is that labor cost realistic?
EDIT: I should also ask this I suppose: should I stick with mostly OEM, or are aftermarket parts just as good/better/worse (like the bostech HPOP on xtremediesel.com)
Like I said, that's the only instance I've really seen of the HPOP dying on an 05+ and it's rare as hell. Most of the time it just leaks and doesn't start anymore. lol
I mistyped: They pressurized the HPO system, diagnosed leak secondary to cracked HPOP block. They recommended to replace HPOP while the were at it in case the HPOP failed soon, and I had read that the HPOP was a big problem on these trucks so that made sense to me considering the labor to get to it.
I got a quote from a shop to do a full bullet proofing, including studs and it was in the $7k range. I did what's in my sig for less than $3k having someone else do the work (parts were sourced by me at around $900).
How did you find this shop? Maybe you can check their reputation with your local FTE chapter or see who they would recommend. The later HPOPs are pretty reliable and cheezit is one of the top experts here on FTE.
Too bad people don't live closer to IA. The guy who did my bulletproofing did it for an excellent price. I think it ended up being about 3500 dollars (parts and labor) for ARP's, OEM gaskets, 4" MBRP straight exhaust, SCT Tuner, IPR Gen 2 EGR delete with up-pipe, coolant, oil change, turbo cleaning, intake cleaning, STC, stand pipes, dummy plugs, turbo drain and feed lines, FICM and injector diagnosis and 2 injectors installed, and some other stuff. He's a Ford master diesel tech at a dealership as well.
I would easily agree. He did an excellent job and had it done in about a week doing it outside of work. I asked him about getting a 6.4 after this truck and he said he wouldn't drive a 6.4 if you gave it to him. lol
Don't mean to hijack the thread but I'll second the worth the drive part^^^^^^. I have an '03 that did have an HPOP failure and the repair with the EGR delete was right at $2800!! That was last year and I have taken it upon myself to learn how to do most things myself!! (Just changed my oil cooler and turbo myself for obviously just the cost of the parts.) Hate to think for just that much more I could be bullet proof!
I can understand doing some preemptive repairs, but that estimate is way over the top. I would recommend that the op does some price shopping with some other shops.
