no brakes
Old 06-30-2013, 03:22 PM
Dennis Bloxham's Avatar
Dennis Bloxham
Dennis Bloxham is offline
no brakes
I bought a 1951 Ford F600 dumptruck everything checks out but the brakes. I have to pump them at least twice before i get any pedal and then the brakes work great. we have bled the brakes but it didn't help. Can anyone help get me started in the right direction?
Old 07-01-2013, 09:55 PM
fixnair's Avatar
fixnair
fixnair is offline
I'd look at adjusting the brake shoes out some more and if they are already adjusted properly then I'd look at getting a new master cylinder.
Old 07-03-2013, 06:50 AM
Dennis Bloxham
thanks for the info
You were right, my mechanic tried to adjust the back brakes and we found we need new shoes. this is a 2 ton truck so nobody carries a shoe for a 20 inch wheel that is 60 years old. I'm hoping that i can get them relined. thanks for your help
Old 07-05-2013, 05:21 AM
big job's Avatar
big job
big job is offline
Linnings should be no problem. You have to go by lenght, width, no. of rivits
dont tell em what its for (could be for a fork lift or something) not important
for a real brake supply place.
Old 07-07-2013, 06:07 AM
petey shoes's Avatar
petey shoes
petey shoes is offline
sounds like you should be doing all four corners. linings do, and will, become brittle and dry over time. just because they have a nice thick lining that looks ok--doe not mean they are good.
Old 10-27-2013, 10:27 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Making sure that beast will stop before you worry about other things is an excellent plan . You can get your old shoes relined at a brake and clutch rebuilder in your area if you cant find anything off the shelf .
BigBlockF350
56
04-02-2013 05:55 PM
Gettysburg150
03-25-2013 10:26 AM
mjacobbe
06-05-2005 11:17 AM
idealtrucks
12-23-2003 09:37 AM
dab38
08-26-2001 02:35 PM
Quick Reply: no brakes
