1960 Turn Signal Wiring Schematic Needed - Horn Question too
Old 06-26-2013, 03:35 PM
montego69's Avatar
montego69
montego69 is offline
Hi all,
Does anyone have a schematic for the wiring harness for the turn signal switch in my 1960 F100? I'm trying to match up the wires on my new Speedway Motors 20 circuit kit to the factory turn signal wires. It seems as though the wiring kit is GM based: It has a flat connector that I can tie into with the stock Ford wires. Just don't know for sure which wire color connects to which one in the kit.
For the horn, i'm also assuming that the wire in the kit's flat steering column connector needs to be pulled out and run through the firewall to where the horn wire comes through the steering box, correct?
Thanks all,
Nick in WI
Old Brown Truck
11-13-2014 01:11 AM
dharte
11-02-2014 09:49 PM
mikeescott
Electrical Systems/Wiring
01-19-2005 10:03 PM
53Merc
08-31-2003 01:48 PM
jml
05-22-2002 10:57 PM
Quick Reply: 1960 Turn Signal Wiring Schematic Needed - Horn Question too
