1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
brake problem
Old 06-24-2013, 01:14 PM
twall_SD250's Avatar
twall_SD250
twall_SD250 is offline
brake problem
i replaced my front brake pads and rotors about 6 months ago. As i was driving last week i heard a squealing coming from my front left brakes when i apply my brake pedal going slow. i pulled the front wheels and the pads still have more then 1/2 the thickness left and the rotors are not warped. What would cause the front left pads to squeal does anyone know? When i had the wheel off i sprayed brake parts cleaner all over the rotor and pads just incase something was caught up in there. After i put the wheels back on it stopped squealing for a day or two then the squealing came back. I'm stumped, does anyone know what would cause this. if i apply the brake pedal hard it doesn't squeal it only does it when i apply light pressure to the brakes. i hope someone has a simple answer to this. thanks in advance
Tim
Old 06-24-2013, 01:59 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Sounds like cheap pads or no anti-squeak goop on the calipers.
Old 06-24-2013, 02:54 PM
twall_SD250
The pads were from ford and there's pleanty of anti squeak on the back of the pads. The pads are basically glued to the calipers.
Old 06-24-2013, 06:28 PM
redford's Avatar
redford
redford is offline
Received 1,591 Likes on 929 Posts
Are your slide pins sticking?
blockmanjohn
09-25-2007 01:30 PM
amm888
General Automotive Discussion
12-04-2006 09:51 AM
fordtrucklover94
01-19-2005 02:25 PM
johare
1983 - 2012 Ranger & B-Series
12-27-2004 08:32 PM
Sudsrat
1978 - 1996 Big Bronco
05-04-2003 06:45 AM
Quick Reply: brake problem
