1992 F150 5.0 302 v8 diagnostic nightmare, wont rev cutting spark fuel or timing
as listed in the title my newly acquired 1992 f150 2wd auto 302 will not rev past about 2000rpm in idle or drive without completely falling on its face(literally flooring the car does nothing but make more noise but produces no power) and bucking horribly and the intake noise changes from a normal sucking sound to a gurgle vacuum noise, the truck starts and idles flawlessly with perfect 10degrees of timing with spout out and advances properly with it in. The Truck is completely un-drivable and only does about 20mph and will maybe slowly gain more speed but any touch of the peddle does nothing.
new parts replaced
new cat
02 sensor
TPS (properly adjusted)
plug wires
TFI ignition module
Reman PCM
new Fuel pressure regulator
plugs not that old
new fuel filter
new upper and lower intake manifold gaskets
cleaned and properly working IACV
new MAP
New coil
Ran KOEO codes and did KOER codes too. KOEO codes 31 85 33 34
KOER codes 31 25
this didn't really reveal anything that would help my situation,
so my best guess are as follows, MASSIVE air leak causing a lean condition so the truck wont rev, PCM not happy with something and cutting timing, spark, and or fuel.
I tried spraying fuel into the throttle body to see if it would pick up some revs while I was simulating the issue but did nothing leading me to believe its not a fueling issue, also with the fact that the truck has dual tanks dual fuel pumps and both pumps don't change the problem.
I am at my wits end! ANY IDEAS???
new parts replaced
new cat
02 sensor
plug wires
TFI ignition module
Reman PCM
plugs not that old
new fuel filter
new MAP
New coil
KOER codes 31 25
I didn't say they were "bad' I said they may be plugged. If they are the original injectors they're 21 years old. If you look at the end of a ford injector the holes are smaller than the point of a pin, and have be cleaned with a special solution. But don't take my word for it I've only been working on my 89 for about 15 years now
