Help finding a C6 transmission
Hi guys,
I'm a new member, thanks to buying a '65 F250. My name is Mike, live in No CA, San Jose. Area. Truck has a 4 on-the-floor, and I'm looking for a C6 tranny for my FE motor, as the current tranny needs repairs, and any help or direction would be appreciated. Thank you,
Mike
Mike
Welcome to FTE. You are tackling a much bigger project with the C6, as opposed to replacing or rebuilding the 4 speed. Look for a C6 that came from an FE, so that the bell housing will bolt right up. Try a search of this forum. There are a number of members who have swapped in a C6. Good luck.
Kurt
Kurt
Thanks guys, I've checked SJ pik n pull, no luck locally, but people spoken to have no idea of what an FE is, or there is no way to include it in searching their site. Someone posted a site for a new one & I can call them during the week. I am not a mechanic so all input is greatly appreciated, thanks again. Mike
F100 F250 PARTS 67 68 69 70 71 72
Ford C4/C6 Transmission W/2 Year Warranty
FORD FE C6 AUTOMATIC TRANSMISSION
all within 50 or so miles
C6 converter housing is made as part of the transmission case.
You will need a C6 from one of these trucks, as the 1966/71 FE car C6's have different length output shafts and extension housings.
Originally Posted by dogluvr
Bill, are you saying that I can use the 66/71 FE car's C6?
1965/67 F100/350 352 (1965/72 F350 300 I-6) came with MX Cruise-O-Matic (14 trans pan bolt holes, has a separate converter housing).
1968/76 F100/350 360/390's came with C6's (17 trans pan bolt holes, converter housing made as part of trans case).
MX Cruise-O =
Hi guys,
Mike
Mike
