anyone installed 4.5" bolt circle disc brakes on a 57-64 F-100 ?
Hey all, has anyone installed 4.5" bolt circle disc brakes on a 57-64 F-100 ?
I know the F100/150 rotors will fit with 5 on 5-1/2" bolt circle, they could be re-drilled to the 4.5" pattern. It would require a fare bit of machining to relieve the back of the hub to clear and seat the wheel stud heads. The next problem is the size of the hub shoulder that centers the wheel, it's to big for my wheels, plus the hub is to long, my center caps won't fit.
I have been trying to adapt Granada disc's, have them working with the spindles now, just need to pick a caliper that will work with the spindle to disc offset.
Anyone have some idea's
Hillbilly63
06-19-2013 02:35 PM
