61-63 302 / 332 Intake and Exhaust Manifolds
Hi there,
Really enjoy all of the shared knowledge available on this site.
Like many before me, I am looking for some much needed parts.
Trying to find an intake manifold and set of exhaust manifolds from a 61-63 302 / 332 heavy duty engine [the Lincoln-derived blocks].
Trying to convert to the later model carb set-up and need the later intake to do it.
Thanks, in advance, for any assistance I an get.
- Roby
- Roby
Very little info here, and less parts:
LINCOLN Y
https://www.ford-trucks.com/forums/7...k-guys-at.html
I don't find much else. I'm sure you've done the searches as well. Slim pickings for that motor I'm afraid.
LINCOLN Y
OP wants to install later carb, but failed to mention if it's a 2V or 4V. It's difficult to help people when they fail to list all the info.
So, until I know, cannot help with part numbers/applications for intake manifold.
302/332 came with unique Rams Horn exhaust manifolds (R/L same) not shared with any other engines.
1957/61, 1962 before serial number 310,001 came with: COTE-9430-A
1962 from serial number 310,001, 1963 came with C3TZ-9430-A
Sorry about that.
You are absolutely right.
The manifold I'm looking for is a 4V
I believe the casting number is ECT-9425-C.
The engine on which I'm wanting to install the parts is a 1957 368ci.
Number Dummy, I've read several of your posts here and the information you provide is unbelievable. Any idea on the differences between the COTE and C3TZ castings?
Thanks again for the info sharing.
- Roby
- Roby
Nick-1973-ford
05-31-2019 09:28 PM
ToddOuzts
01-29-2018 01:44 PM
BERRY FARMER
13
09-13-2015 04:27 PM
kelwar
07-18-2011 11:18 PM
