gearbox z dpf-r+ experiences???
Hi. I've been lurking this site and others like it since I bought my '08 f250 new in fall of '07, but this is my first post!?!?. I was waiting for warranty to expire then was going to pull the trigger on a minimaxx..... well two things have happened since..... 1) no more race tuner as you all know and 2) money has become an issue. I don't really want/need all the extra horsepower, but am looking for a more economical was to increase the longevity of my truck.
So..... Does anyone have any real experience with the dpf-r+ from gearbox z? Is it safe? Last thing I want to do is blow head gaskets and the like. Is it reliable and easy to install/uninstall? How is the companies service?
I don't really care about how much better Spartan/H&S are, as that is not an option for me right now. I would just like to know about the dpf-r+.
Thank you, and fyi.... I have learned a lot from you all over the years!
Do a search on here. I have investigated it myself, but about to buy an extended warranty I think, so i put it off until I decide. I know one member had a problem, not much of one if I remember correctly. I've heard that the biggest complaint is being able to hear and follow the directions.
I have commented on this topic a few weeks ok. Search "transmission searching for gear with DPFR+4.0". Overall I like the product but it is causing my transmission to not shift right. Well, at least I believe it's the programmer, could be the tcm I guess. I'm just running the dpf delete only option now until I have time to figure out what is going on.
Goodluck
If u ONLY run the gearbox Z by itself & NOT stack (use) it with another performance tuner and/or monitor - you will be fine & like the gearbox z tuner
They make one with a small performance boost which has a "+ " in part #
The other that retains ALL STOCK programming & ONLY deletes the re-gens has a "-" in the part #
I completely removed both EGR Coolers & the rear exgaust pipe that feeds them then plugged the coolant ports.
Less Heat & Less Clutter under the hood, plus no chance of dumping soot or coolant down my engines throat
I also removed the stock Intake Elbow that houses the EGR valve & replaced it with an aftermarket Aluminum Elbow.
I did have to wire in some Diodes to keep the chk eng light out :
https://www.ford-trucks.com/forums/1...installed.html
Would love to hear some follow ups to this topic as I am considering going with the gearbox z. Want to do the EGR Delete as well. Sorry to hijack but seemed fitting to post in this thread. BrownDog. Can you go into more detail about completely removing the coolers and rear exhaust pipe? Is that the same as the "up pipe"? It sounds like you did a lot more than just install the blocking plates.
Mike.
Mike.
Mike.
Mike.
