66 F100 Front Suspension
Yes the aerostar is about a bolt in with some fabrication, as much as a Panther chassis Late model Crown Vic. The aerostar is a steel unit where as the CV is a cast aluminum unit. The first generation flat nose units were used and they are getting pretty hard to find as most have been scrapped. These are a good source for a AOD shifter as it was floor mounted.
There are much better options out there.
Dakota Kits : Industrial Chassis Inc.
WIDE RIDE IFS - COILOVER-No Limit Engineering
Some of the better ones,
Garbz
Garbz
As a former professional suspension Builder/Installer i would not recommend the Crown Vic to my worst enemy. The CV uses shims just like the Aerostar and requires a fabricated rear lower a arm mount. I have issues with using a cast aluminum cross member designed for a extremely rigid frame structure on a non rigid "flexing" ladder type truck frame. I saw a movie starring Jimmy Stewart in my youth and have not gotten over aluminum and cyclic metal fatigue since. Failure is a mathematical certainty.
Nothing is a truly bolt in. Everything out there requires a bit of fabrication or modifications.
The Dakota based IC kit has taken most of the thinking out of the process (tab a into slot a) and allows the truck to retain the GRVW it left the factory with for towing or loads in the bed. This is the only kit on the market to allow this.
Each kit is custom designed to fit the frame application of the year truck you have. You can also retain your 5 on 5.5 ford truck pattern by using D150 rotors and calipers that area direct bolt swap to the Dakota early or late spindles.
Another used suspension is to use a JAG unit. I have even seen early 80s Volvo units installed.
Garbz
Garbz
The aerostar also has a inside rail width of about 34 1/4 inches and fits almost snug to the rails once you cut off all the unitized inner rail sections. .
The Dakota is also the same track width as the 1 to 77 trucks.
Garbz
Have you thought about the Jaguar front suspension swap?
It comes in 2 different widths, and if you want to has IRS. Plus whole cars can be had for less then $700 often in my area. I almost got a whole runner for $650 with a fairly low mile 350 sbc for my DD. It wasn't smog legal, and they come up like that a fair bit too.
You need the upper and lower A arms, spindles and rack ( most had power steering).
Call Steve at IC and he can give you all the skinny and supply you with engine mounts for the Windsor. He can also guide you on how to hook up a column to the rack.
Here is a facebook post of one of Steves units about to be installed in a 63
https://www.facebook.com/media/set/?...3192640&type=1
Garbz
The Jag has 4 piston calipers in the front and 2 piston calipers in the rear.
Kevin
