Firestone airbags not leveling F350
Installed a set of firestone air bags on a 2013 F350 dually this morning. Owner was pissed when he first hooked up his trailer, an easy 4" of sag when it was on. For comparison, his 2004 F350 dually sags maybe .5-1" with the same trailer, not sure what it weighs
We aired up the bags after i was done, to 85 psi and the truck still sits about 1.5"-2" lower in the back. Do these things really sag that bad? Anything else we can do to level the truck out with a load?
Interesting to hear this because my new 2013 F350 SRW CC doesn't squat at all with the 16K toyhauler on the fiver. I do have the snow plow prep in front so the truck is level to start with but with the fiver on I'm barely touching the helper spring - might be down .5 to .75 from unloaded, no more.
these new trucks are just big soccer mom trucks, this past weekend my cousin wanted to sod his yard at his new house. Said ill lend the F350 for the work, two pallets of FRESH sod in the bed and three pallets on my 16ft 8k landscape trailer and i was still riding REAR HIGH. Yet a brand new F250 diesel next to me only had one pallet and was sitting like the rear springs were busted! The guy was like "i should have ordered a F350 instead" i laughed to myself and just said "yea thats why i did" but we all all know that isnt the real reason
Just found this so so quality cell phone picture of the truck with the fiver attached. Not perfect because things are on level ground but I think you can see that there is almost no sag with the RV on the truck. No modifications to the suspension. 20" wheels with the Michelins. I think you can see from the wheel wells that the truck is level with the trailer on. On flat ground it is level - we measured sag at the RV dealer and it wasn't enough to write home about.
No offense taken. On level ground we measured between .5 and .75 sag. Not none but not enough to put us on the helper spring. In this photo the trailer is sloping uphill, the truck is sloping downhill. Like I said, not a great picture because the ground isn't level.
That's pretty impressive for no airbags I think. Maybe he has the trailer filled with helium or something.
