08 F250 wont crank over
see this:
The truck should start. Reconnect the wire, close the hood, andcheck for codes. You will likely have a code for EGT-13 open circuit, overtemp, out of range.
DISCLAIMER: USE THIS INFORMATION AT YOUR OWN RISK. IF YOURVEHICLE IS INDEED EXPERIENCING AN OVER TEMPERATURE CONDITION THERE IS RISK OFVEHICLE DAMAGE AND POSSIBLE FIRE OR TOTAL LOSS OF VEHICLE. THE AUTHOR OF THISPOST ASSUMES NO RESPONSIBILITY FOR THE INFORMATION PROVIDED WITHIN. USE THEAFOREMENTIONED INFORMATION PROVIDED AT YOUR OWN RISK TO SELF, VEHICLE, ANDPROPERTY.<o></o>
<o></o>
- Parking brake SET <o></o>
- Key in the ON position <o></o>
- Open hood <o></o>
- Near the RH battery, there is a single wire disconnect. It is attached to the battery box. Remove it from the battery box and disconnect it. <o></o>
- Touch the end headed towards the starter to the POSITIVE terminal of the battery. <o></o>
<o></o>
Ryan Lewis
1999 to 2016 Super Duty
02-19-2018 12:03 AM
2KF3504X4
17
09-05-2015 04:23 PM
new2diesel2
1997 - 2003 F150
11-06-2007 02:47 PM
