NEED HELP WITH FUEL GAUGE!!
Hey guys and gals i need some help with wit fuel gauge on my 1995 f150 5.8 4x4.
I've searched and searched this issue and cant find anything on it so heres what it does.
Every once and awhile my gauge will work fine for a little bit and then it just jumps to way past full (ground issue) and it will stay there for sometime and go back to normal eventually, maybe in 5 min or two weeks. I have looked at the plug back by the gas tank, took the cluster out and checked back there, and by the kick panel and still nothing so any help would be wonderful!! Thanks in advance!
I would agree that dropping the tank is probably the only way to determine the issue. You may also want to remove the pump and have someone watch the gauge on the dash while you move the float up and down and check the wiring. You might get lucky, wiggle just the right wire and the gauge pegs, identifying the short.
Bootlegger's Deluxe
26
07-01-2017 12:05 PM
forager
07-29-2014 11:05 AM
Fordpup
07-04-2007 09:36 AM
boogity24
02-17-2004 03:36 AM
