Bronco II Ford Bronco II
setting the clock radio
Old 06-09-2003, 01:42 PM
Bgrossenbacher's Avatar
Bgrossenbacher
Bgrossenbacher is offline
I just bought a 90 XLT 2wd. Does anyone have the info to set the clock or the presets on the factory cassette radio? thanks
Old 06-09-2003, 06:37 PM
GrayRanger4x4's Avatar
GrayRanger4x4
GrayRanger4x4 is offline
Clock- Push the on-off **** and hold use the seek and/or scan buttons to set time
Set radio- stations find station push and hold a number till station comes back on,.
I hope this helps and I hope its right. The clock might not be just right but it is close .Maybe some one can get it right for you if this doesnt work.Good Luck
Old 06-09-2003, 06:52 PM
Ken00's Avatar
Ken00
Ken00 is offline
Welcome to FTE!!!
Old 06-10-2003, 11:36 AM
GrayRanger4x4
Thanks Ken00
Old 06-24-2003, 02:27 PM
JayRobyn's Avatar
JayRobyn
JayRobyn is offline
Also, I'm not sure I have this totally figured out yet, but it seems that when I disconnect and then reconnect the battery, the clock/radio changes "mode" from displaying the station frequency to displaying the time while it is turned on. I can't get it to change by just pulling fuses, but I'm sure there's a easier way. The manual doesn't mention this!
Old 07-10-2003, 09:45 PM
david.brady's Avatar
david.brady
david.brady is offline
Setting is correctly mentioned. To change display, just push the on/off button once to toggle between modes.
tjc transport
03-15-2017 08:00 AM
edjunior
1999 to 2016 Super Duty
04-29-2016 12:00 AM
IsaacJR75
06-11-2015 07:45 AM
jerwiltho
03-10-2013 05:22 PM
Redstar95
Aerostar
07-30-2007 11:16 PM
Quick Reply: setting the clock radio
