Ok I'm trying to replace my steering box due to 1/3 turn of play. I have a Chevy 327 in it. I've removed the headers but I still can't get the damn thing out. The spline that goes through the frame still needs another 1" or so before it's free. The steering box is hitting the canister oil filter frame and maybe the engine block. My next step would be to unbolt the engine jack it up and try to move it over an inch.
Will the engine move an inch if I just unbolt the motor mounts? Has anyone had this problem?
If you have an engine crane you can lift it off of the mounts enough to get the steering out. I wouldn't try to move it over an inch if you don't have the engine supported with a winch or a crane from above, it would be too easy to push it off of the jack. Is the transmission still in it and connected? You might have to unbolt it off of the crossmember and pull out the dipstick/fill tube if it is an automatic.
FWIW, I just installed the steering box through the cab, into the frame of my F4 with the SBC in place, oil filter removed. The crankshaft is within 1/2" of the height of the original engine shaft.
If you must raise the engine, try jacking from below.
Ok took off oil filter, still no go. Jacked up the motor over an inch and it still wasn't nearly enough and now it's not aligned on the mounts. Next step in this never ending saga is to go rent a cherry picker and lift the motor at least 2" after I loosen the transmission mount.
I'm surprised you are having so much trouble. I have a CSB 400 and had no problem getting the column and box out when I put in the Toyota box. Didn't have to touch the motor, header or filter. I removed the wheel and the floor plate and took it out thru the cab.
I just wanted to give you some encouragement. You will get it out ,that's for sure. It's to bad I've moved, (I went to Oceana in Sharp Park) Id swing by and try to help. Good luck with it.
I think what you're saying is the shaft that goes through the frame and connects to the stock pitman arm. Maybe it's the way the sbc was mounted? I have a sbf. By the way, this hobby is a never ending saga. Welcome to the nut house.
Heah guys Im just thinking out loud here but, if he was to back off the pitman arm nut and remove the pitman arm, and then open the other side of the box, could he turn the steering wheel to just turn the worm gear to rotate the sector shaft out towards the block? Once he clears the sector shaft bushing, it may give him that extra inch. Sorry, I lost all those exploded views when my computer crashed, and I cant seem to scan with windows 8 (surprise). hutchie, please don't try this unless some other folks think it may work, I may be way off. PS I haven't met Jerry yet.
