Fail-safe mode??
Fail-safe mode??
Hi....
Here's what happened to me yesterday....
'02 Expedition w/120k miles (15k on a new engine).
Out of the blue, I stopped accelerating, lost most power. The "check engine" and "oil pressure/engine coolant" lights were on. It was taking forever to shift, a/c completely stopped working so I turned it off. I struggled to get home (about 2 miles) and actually made it. Read the owner's manual & checked the coolant....it's completely dry. Oil is fine. I'm guessing now that it's running in fail-safe mode.
My question...after I fill the coolant, what should I expect? There was no warning, no overheating before this, no puddle of leaked coolant in my driveway, no warning lights on in the dash.
I appreciate your input!!
Warped heads or blown head gaskets are the first problems that would arise from overheating an engine. A compression test might be in order to verify if all of the cylinders are okay.
Update....the reservoir wasn't totally dry when I put the coolant in...very, very low, and almost completely gone, but not dry. I filled the coolant, started her up, and it ran fine. A/C worked immediately, lights were off, drove down the block and back & there were no problems.
But...the check engine light was on.
Any ideas on what's next??
I would keep a gallon jug of 50/50 anti-freeze (or at least water) in the cargo area so you are prepared if you discover a low reservoir.
kr98664
02-15-2022 01:24 PM
kendrickevans30
1997-2006 Expedition & Navigator
16
07-02-2013 12:27 PM
79 f-150 guy
20
05-04-2011 12:39 PM
tm3912
04-22-2006 12:30 PM
