1964 f250 with a 292 y block want to upgrade to 4 bbl
Old 06-01-2013, 02:12 AM
raider69guy's Avatar
raider69guy
raider69guy is offline
I have a 1964 ford f250 with a 292 y block in it i would like to upgrade the intake manifold and put a 4 bbl carb does any body have any ideas please help
Old 06-01-2013, 02:23 AM
raider69guy
i need some advise on this please help!!!!!!
Old 06-01-2013, 06:22 PM
tomfiii's Avatar
tomfiii
tomfiii is offline
go to
Y-Blocksforever Forums
there you can read to your hearts content and ask questions on 4 bbl's
Old 06-03-2013, 07:25 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Find an old junk yard and start looking at cars. 292 & 312s both came out with 4 barrels in some models. If you find them it's just remove the 2 barrel manifold, add new gaskets and install. I run a Holley 390 CFM on my 272.
BJ
Old 06-24-2013, 01:18 AM
NONclow's Avatar
NONclow
NONclow is offline
ECZ-9425-A: small ports, matches early heads better, older "teapot"/"birdcatcher" carbs are harder to find parts for also need an adapter plate to use anything but
ECZ-9425-B: larger ports, better matched to ECZ-G or similar heads, AND they accept modern Holley square flange carbs.
I also used a 390cfm on mine...got three 94's on it now
Old 06-24-2013, 07:25 PM
stoffer's Avatar
stoffer
stoffer is offline
back in high school, I used a 2 barrel to 4 barrel adapter on my stock 2 barrel intake, and added a Holley 390
it really woke my ol' 292 up
robbyriot
04-05-2015 11:02 AM
redbeard_trucks
06-22-2010 11:16 AM
WALFORD'S 56
11-28-2007 09:03 PM
gota292
13
09-13-2006 04:50 PM
Quick Reply: 1964 f250 with a 292 y block want to upgrade to 4 bbl
