Lifter noise?
Old 07-31-2012, 02:51 PM
limegoldf100's Avatar
limegoldf100
limegoldf100 is offline
Lifter noise?
Maybe this has been discussed before, but I have a 2002 Ranger 3.0 purchased 2 years ago on eBay. It was advertised as having lifter noise.
When I got it, it had a lot of noise at idle and at speed. I poured a lot of products through it (Seafoam, Lucas Oil, crankcase cleaner). Eventually, the noise disappeared. A couple of months later, it came back but different. Now, it's nearly silent at idle but gets much louder as it speeds up, particularly under a load.
I have had a couple of good mechanics listen (one cut his teeth at a Ford dealership) and he's sure it's lifters. Another is thinking timing chain.
Anyone with a similar experience? At 144,000 miles, it runs fine, burns no oil, has adequate power, but the sound is really annoying.
Old 05-25-2013, 10:31 PM
aswingerat44's Avatar
aswingerat44
aswingerat44 is offline
Ouch.
If it sounds like this it is probably a lifter rod.
On Exploded diagram ,# 11 is the suspect. I had a labor quote for $ 1700
to rebuild the whole engine.
2013-05-25_2028 - organians's library
JohnOsky
07-27-2010 06:32 PM
spquint
1983 - 2012 Ranger & B-Series
05-06-2007 06:29 PM
hi-jacker
11-25-2006 07:38 AM
ripcurl94
02-21-2006 12:19 PM
tcmullenix
03-02-2002 07:52 AM
Quick Reply: Lifter noise?
