Left rear brake hose 2002 screw
Need to change the rear left brake hose at the caliper,2002 f150 5.4 auto 4x4 supercrew 4 wheel disc
The steel line from the hose on the differential, at the backing plate bracket has what looks like a round fitting?
I am thinking that this is not a flare nut but looks like one piece with the line,haven't disconnected it yet,am I correct?
The brake hose I purchased from a local parts store, Raybestos Bh382726 checks out as well at rock auto to be the right one.
The index on the bracket has 2 notches and the hose I bought has the part round to hex index, it won't fit.The banjo end is wrong to.
I did a search and found I am not the first to run into this.
A few had made do with a modified front hose to get by.
I'd rather not do that if there is a better solution.
Any help is appreciated thanks
Forgot to do a follow up on this for the next guy that runs into this.
The rear brake hoses on a 9.75 axle with rear disc brakes are not
listed as an option in any aftermarket parts I researched
The hoses for the 8.8 diff won't fit as they are.
The hose and the steel line are indeed one piece on each side
I found Ford numbers I believe to be correct but can't remember the source
6L3Z-2268 and 6L3Z-2267
Went a different route so I never checked out the oem hoses
rickm15752
07-11-2017 10:30 AM
conoso
05-16-2014 11:45 AM
DieHardChief
11-05-2013 01:17 PM
Keepin It Real
05-03-2007 11:08 PM
