ABS Grease fitting ?
Old 05-23-2013, 10:26 PM
bakerbuilttracks's Avatar
bakerbuilttracks
bakerbuilttracks is offline
I read a while back about installing a grease fitting in place of the abs sensor to grease the hub/wheel bearing.
I found these Riffraff Diesel: Front ABS Grease-able Block Off Fitting from clay while looking at the cost of an AE " they were on the same page ".
My question is this ......
By installing and using them which Bearing dose it apply grease to ? The needle bearing that the front axel shaft rides on. Or the actual sealed wheel/hub bearing.
Any one using these ? how are they ? do they really help the longevity of the front wheel bearings. Ive put 2 or 3 sets of hub assy on my truck in 6 years and if it will help not having to do that "As much" I'm sold.
Old 05-24-2013, 05:28 AM
grec-o-face's Avatar
grec-o-face
grec-o-face is offline
When Andy (snowseeker) made his first run of these (though not anodized and shiny) I took a few pics of the grease fitting and how the grease moved through the bearing. It looks like the needle bearing doesn't get the added grease as the sealed hub bearing certainly does...
Ford Truck Enthusiasts Forums - View Single Post - Brotherhood of the travelling hub zerk
EDIT: After reading my old post, it seams back in 2011 I didn't know how to spell... "greese" vs "grease"
Old 05-24-2013, 06:16 AM
srteach's Avatar
srteach
srteach is offline
I have 2 of the RR fittings. They grease the internal sealed bearing that the truck rides on, not the little axle bearing (NAPA bearing #B2110) that is visible on the inside of the hub.
Those little bearings are easily replaceable, but do need to be hand greased.
Old 05-24-2013, 09:42 AM
HKusp's Avatar
HKusp
HKusp is offline
I believe Scott (Texas Outlaw) was the first to make a run of these, and he actually gave them away to anyone who wanted one at the time, just for the record. I haven't seen him post in quite a while though. He's a very good dude.
https://www.ford-trucks.com/forums/member.php?u=347252
Old 05-24-2013, 09:48 AM
grec-o-face
Show's how much I know...
Old 05-24-2013, 09:59 AM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
How can I find out if I have the right axle that this part will fit? Thx
Old 05-24-2013, 11:05 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
You do.
Originally Posted by buzter
I have a 05' F250 4X4 FX4 and recently had a 05' F-150 4X4. Just got rid of the F150...after using the zerk on it...Well heres the story...I also have a 04' Tahoe...took the rotors and mounting brackets off today..and looked in the back...hmmmm ABS bolted in the same way..so I figured might as well check it out...took out the ABS, held in the same way as the fords with a small bolt...and guess what fits...the hub zerk.....just lettin ya know...This thing is versitle (sp)...
Originally Posted by hav24wheel
Same thing works on my wife's Town and Country too. Lol
The "WIFE'S" tahoe is a 2004 and it has the abs sensor in about the same exact location as my 2005 F150. And it was an exact fit. I was happy to be able to grease them.
Stewart
Old 05-24-2013, 11:18 AM
Stewart_H's Avatar
Stewart_H
I believe Marv was the creator for the original zerk, turning one on his lathe. It was his design that Tex followed.
https://www.ford-trucks.com/forums/6...ml#post5019968
Stewart
Old 05-24-2013, 12:52 PM
cps's Avatar
cps
cps is offline
So what happens to the ABS system now?
Old 05-24-2013, 12:56 PM
Stewart_H's Avatar
Stewart_H
What do you mean?
Greasing the hubs this way doesn't affect anything with the ABS.
Stewart
Old 05-24-2013, 01:20 PM
cps's Avatar
cps
cps is offline
Originally Posted by Stewart_H
What do you mean?
Stewart
What i meant was, if you remove the ABS sensor i am assuming it will throw a code if you do not re-install the the sensor after greasing, right? Now with all that grease in there, i was wondering if it affects the sensors ability now. Maybe a dumb question, but i like to ask them instead of dumb mistakes.
Old 05-24-2013, 01:26 PM
Stewart_H's Avatar
Stewart_H
Not dumb. Without you being specific, I didn't understand what your question was.
Adding the grease through the ABS port does not affect the ABS sensor in any way.
Stewart
Old 05-24-2013, 06:09 PM
srteach's Avatar
srteach
srteach is offline
Stewart
Stewart is correct. There is no effect on the ABS if you re-install the sensor.
If you leave them out (as I have), the ABS system is disabled, which does not affect braking in any way. You will have the ABS light on until it burns out or is removed from the instrument panel.
You can use the fittings if you do not have the ABS. You just have to get the ABS hubs, remove the sensor and place the grease fittings in their place.
Old 05-24-2013, 07:18 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Please be sure to not throw away that ABS sensor that you remove. Save it for someone here that may need one someday.
I can't believe the "question for Cookie" was asked six years ago!
Where does the time go?????
Pop
Old 05-27-2013, 04:59 PM
Texas Outlaw's Avatar
Texas Outlaw
Texas Outlaw is offline
Not a liberal...
Ford Truck Enthusiasts Forums - View Profile: Texas Outlaw
Sup bro?
I did make a run of these. Have been trying to make another run but just haven't had time. The company that I have worked most of my life for was recently sold and the new owners work me into the dirt, hence the no time for anything. Am about to make a change though....
Quick Reply: ABS Grease fitting ?
