Type of rear-end?
Type of rear-end?
I replaced my original 55 rear end with one from a 69 F100. I've got a leak on the axle seal. Auto parts guy tells me that there are 3 types of seals depending on the type of assembly I have. The tag that was attached to the differential housing reads. "WDM-S 9EA 25 9. 313B" Does this tell me what type of assembly I have.
Thanks for any help.
Erinaldi
Erinaldi
<table style="border-collapse: collapse;" id="table1" border="1" cellSpacing="0" cellPadding="2" width="98%"><tbody><tr><th bgColor="#fae9d1" rowSpan="2">Code</th><th bgColor="#fae9d1" rowSpan="2">Application</th><th bgColor="#fae9d1" colSpan="2">Ring Gear And Pinion</th><th bgColor="#fae9d1" rowSpan="2">NL
or L</th><th bgColor="#fae9d1" rowSpan="2">Axle
Shaft
Splines</th><th bgColor="#fae9d1" rowSpan="2">Additional
Information</th></tr><tr><td bgColor="#fae9d1" align="center" rowspace="1.5">Ratio</td><td bgColor="#fae9d1" align="center">Diameter
of RG</td></tr><tr><td bgColor="#fae9d1">WDM-E</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.25</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-F</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.50</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-H</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.25</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-J</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.50</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-K</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.70</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-L</td><td>Ford Pickup '63-'72 F-100</td><td align="center">4.11</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-M</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.50</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-R</td><td>Ford Pickup '63-'72 F-100</td><td align="center">4.11</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr><tr><td bgColor="#fae9d1">WDM-S</td><td>Ford Pickup '63-'72 F-100</td><td align="center">3.25</td><td align="center">9 in</td><td align="center">NL</td><td align="center">28</td><td align="center">-</td></tr></tbody></table>
Shaft
Jeff
BTW, there is a gasket behind that plate you'll be taking off to remove the axle.
If your 9" now has ball bearing style bearings then yes. The axle seal mounts in to the rear end housing then the axle and bearing assembly goes in. If your rear end now has Tapered Bearings then I think the bearing does have to be pressed off. I'm not 100% sure. It's been many,many years since I've seen one still mounted. But that's the way I remember it. You see on the Tapered style the seal is like an end cap of the bearing. Hopefully someone else will chime in soon to back me up.
I had not thought about the possibility that they could have been switched at different times. I always do both sides at the same time. Thanks for bringing that up.
I am still debating whether or not to change the gear ratio and will wait to do the seals and bearings once I decide. If I go ahead and change them then I know I should have a good long time before they are needed again.
Perry55
WTB - Ford Trucks & other vehicles
11-19-2014 10:45 PM
