1986 F250 6-port tank selector
I've been reading alot of posts on this valve and wanted to know if I should check anything in the tank when changing it. The rear tank never has worked. When I switch to the reaar, it sputters and dies out. The gas has been in there so long it stinks like varnish. It seems to be the pumping gas into that tank issue. It also explains the 5-6 mpg. My plan was to drain the tank by siphon, get the replacement valve for $219 and swap that out.
At this point, I'm just assuming that is it. Can I test the valve with a clean 5 gal tank and hose? I thought the pump was in the tank? How can I check that pump? I'd prefer to drop the rear tank and valve. I thought about a LMC 38 gal tank, does that need the bed off?
I don't know how gummed up that tank is. I'd like to drop it and start fresh from the valve back, but its an extra truck I use occasionally for hauling and don't need to drop $600 into it.
from here, i would suspect the pump in that tank has failed, or will fail soon due to the old gummy fuel in there. i would suggest pulling the tank, opening it up, and deciding if its worth cleaning out or just replacing.
if your goal is to stay low-budget and you don't really need the second tank, it wouldn't be hard to simply bypass the TSV and only have the single tank.
if you decide to get the current rear tank back into use, i would suggest putting a cheap clear filter in its line before the TSV so any gunk you didn't clean out stops there instead of in your main filter.
and yes, you can test it by running a hose down to your gas-can on the ground.
if you need to get that pump out of the tank, i would do it by lowering the tank just enough to get the sending unit out. this can be done with a floor jack and a block of wood under the tank, with the wood being used to spread the force and avoid damage. support it with the jack and remove the mounting straps, then lower the tank a bit. i've had them apart without disconnecting the fuel filler hose, which is sometimes hard to remove and harder to reconnect properly.
this job it a little easier if you're using a tranny jack instead of a floor jack, but not enough to be worth investing in one.
obviously, when you have the tank open, you'll want to look inside with a flashlight to see just how gunked-up it really is.
1) use your mity-vac to suck on the hose, being careful to get enough air bubbles out so you have a full enough hose of fuel to work with.
2) set your siphon hose in place dry, with both ends at their required point, then point an air nozzle into the tank filler, with a rag loosely in place to help seal and prevent splashing out. the pressure will quickly start the siphon in your hose
3) place a cheap electric fuel pump in the middle of your siphon hose and let it do the work
there are a variety of other ways as well, i just listed the first few i thought of.
your word choice suggests you're using your mouth in the process. this method includes a significant risk to yourself, and there are better/safer ways, which i'll list a couple of
octaneforce
11-13-2011 10:34 AM
sumbeach
11-15-2005 07:25 PM
slimyslim
10-10-2002 05:47 PM
