installing rear fender bolts
I am ready to install the new fenders to the new box for the 1st time. My question is the holes in the box are round. The fender mounting bolts are carriage bolts. I am looking for the correct way to install the bolts. I believe it is to file the holes. But just wanted to make sure.
Thanks
Thanks
link
After a lot more searching I did come across a great step by step
http://www.classictrucks.com/tech/08.../photo_01.html
Ford F1 Rear Fender Replacement Final Photo 1
Maybe you don't need to file the round holes into square holes. I seem to recall that on my new repro bed the holes were round. But, when I tightened the carraige bolt s into place, the corners of the carraige bolt made their own corners as they were tightened. Give it a try and see if your do the same. Jag
My experience has been that the spotwelds on the heads don't give up as easily as shown on that article. I ended up just drilling them out from the inside, and using bolts in the hole (the old head makes a nice washer). My bed isn't a show piece, it gets used.
Others have drilled then cut the heads off new bolts (regular hex head bolts), welded the new end to the remaining head, and ground flush.
3twinridges
04-01-2018 06:14 PM
Adriand
15
09-07-2008 06:23 PM
