Help!! 94 7.3 idi auto trans e4od problem
Old 03-27-2015, 12:09 AM
Coz2122's Avatar
Coz2122
Coz2122 is offline
OK... Heres my problem.. 1994 7.3 idi turbo... e4od Trans in her... no fuel gauge working.. no rpm gauge working.. When in D, the truck takes off like a slug... i can shift through the gears and once in drive it will kick from third to fourth... ok easy.. replaced tach sensor.. still nothing.. ok must be the TCM right?? nope that checks out fine... so we hooked up a TCM tester to the trans... all the gauges worked and truck shifted perfectly... any ideas...??? it must be the harness right?? but which one???? any help would be great..
Old 03-27-2015, 12:29 PM
7.3IDIDiesel's Avatar
7.3IDIDiesel
7.3IDIDiesel is offline
clean connectors? only one wiring harness goes from drivers side wheel well down to two connectors to tranny and i think transfer case
Old 03-27-2015, 12:35 PM
Coz2122's Avatar
Coz2122
Coz2122 is offline
I'm told he transmission harness and engine harness are separate
Old 03-27-2015, 12:41 PM
7.3IDIDiesel
yes when i did my manual swap i had the chance for the manual harness but i just hot wired my auto it goes right under the brake booster but i believe the tranny harness ties somewhere into the gauge computer in the dash
Old 03-27-2015, 08:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
did you check the fuses in the power distinction box under the hood yet? there's a couple (im pretty tired out so i didn't look it up to see which ones lol) that if they blow,will take out the tach.with the E40D,no tachy = no worky.
danr1
08-25-2016 07:35 PM
swestermann
01-19-2015 10:55 AM
BORDERBUM
05-22-2014 03:12 AM
Ford400Man
WTB - Parts & other
08-05-2011 04:19 PM
tinker934
08-07-2008 07:35 PM
Quick Reply: Help!! 94 7.3 idi auto trans e4od problem
