'90 F350: weight of cab, frame, and such
Hi,
I am going to do a frame-off of my truck (in signature). This will be my first. As I think about how I will yank and move around the various components, it will help if I have an idea of weights.
Anyone have an educated guess of the weight of:
1. Stripped cab (no doors, glass, or seats)
2. Stripped frame
3. Bed
Thanks,
Roy
2. Stripped frame
3. Bed
Thanks,
Roy
I'm currently doing the same thing but with an excab. It's still a heavy **** and a pain to move around myself. I've been using an engine hoist with straps to lift it and made a plywood and 2x4 platform on wheels to move it around. I would say 500lb (stripped except for glass) is not out of the question. I tried to rock it back so the rear window was on the ground to work on the underside. I'm fairly big and strong but could not do it, had to instead rock it forward from the back and still felt like 200-300lbs of effort.
As for the frame, I cut it in half and the back half and bed became a trailer, the front half (bare frame except for TTB still attached) hit the scrapyard scales at about 800lb. Draw your own conclusions.
I can tell you right now a bare frame does not weight more than 600lbs. I would bet ALL my trucks on that
EDIT:
Just did some more searching. My original Number is low
A FACT that Lighting frame (a reg cab short bed frame,117") weighs 355lbs.
They are the same thickness as a 3/4 and 1/ton frame. That means it is 3.034lbs per inch. So a 168" frame(crewcab long box) weighs 509.74lbs
EDIT:
Thanks guys.
Well, the stuff must weigh a lot...as I am estimating curb weight at 6,500 to 7k.
So, the thinking is:
8' bed, 200 pounds
Stripped crew cab, 400-500
Crew frame, 500 to 700
Damarble, you ran straps around the floor (through the door openings) and then picked the cab up, with an engine hoist, from the inside of the cab (at the center of the floor)?
Roy
8' bed, 200 pounds
Roy
Yep, had the doors off, ran straps to each corner inside and stuck the hoist arm inside. It's tricky to balance.
