Zf-5 speed acting up!
Well awhile ago i was out of town and my zf started going crazy and gears were sticking and it was a mess. so i felt the tranny and it was very hot to the touch. let it cool down for awhile then drove it home. changed the fluid that night but my problem is i couldn't find a fully synthetic Mercon to use, so i had to use cheapo stuff. In the mist of this both fill and drain plugs just happen to be rounded very nicely. Been a few months. nothing happens, then few weeks ago it was making some gear noises so i found some royal purple Full synthetic Mercon, but this time i was not able to get the plugs off. i returned the fluid and the noise goes away. Now.... i have gear noise and all of the gears work except reverse.It just kicks it out and grinds,no matter what i do.
So the question is, could i still have this ZF by getting those plugs off and changing the fluid or buy a rebuild kit and attempt to rebuild it myself?
vise grips? I can't see the plugs being any tighter than the last guy put them in. they're bathed in trans fluid on the inside at all times, so they can't seize in there that badly...
though with reverse still not working, it sounds like there are more problems than just bad fill/drain plugs...
