92 5.0 oil pcv intake
Hey guys it is Markes12344 here, i a currently at the Fields. Therefore i can not provide my 5 obd codes, but they consist of; egr under 2v, egr not opening, fault/rich.
Anywho, here are my truck specs and details:
New 5.0 10months ago, w/ remand injectors.
New injectors A week ago.
New idle control valve and throttle Positioner sensor also a week ago.
Some vacuum lines have snapped and repaired with tight fitting rubber hose over each half of the line reconnecting them.
New spark plugs with motor (a given)
New spark plug wires 4months ago.
Now the problem; when i was replacing the injectors i had oil running down my furthest back, and next to it, port. These are the ones right above the the breather pcv line between the intake and passenger side rocker valve cover.
As i reinstalled everything after swapping injectors, i left the pcv out of the valve cover and started my engine to a idle, upon putting my finger over the hole of the pcv its was sucking air.
What would be causing this?
Also my driver side to air box is oil free.
If it was at the valve cover = An internal intake leak comes to mind.......
78_79ford
09-07-2015 05:48 PM
