How Much Height Can I Expect Out Of A Leveling Kit?
I've got a 2WD 1995 F-150. Like most, the front is slightly lower in the front. I thought about maybe a leveling kit, but how much will it be raised up? (approximately) I'm all about keeping it mostly stock, so I don't want it to look like it's got a 6 inch lift (That's for another truck in the future). But I'm guessing it'll raise it up maybe an inch?
Can anybody please help me out here?
-Cody
-Cody
When I lifted my 2wd 1983 F-100 they used 4x4 coils from an F-150. Be aware that lifting will throw out your alignment, possibly too far to be properly aligned without drop brackets for the I-beams. I am not sure how much room the F-150 has for adjustment but the TTB F-250's cant go more than 2" higher.
I miss my sapphire blue 95 F-150, I had way to much fun with that truck.
Just assuming that your F-150 has the coil springs in the front like my 96 bronco. If so, I put on a 2 inch spacer ring (on the top of the coil spring) to make mine sit and look level. Looks perfect now. Only cost about $175/installed.
-Cody
-Cody
did your truck look like this?
