Headliner
Old 05-04-2013, 10:46 PM
1997fordf350's Avatar
1997fordf350
1997fordf350 is offline
Headliner
Hi, I was wondering on how to fix your headliner? Some days mine is down to my head and on others it's up like normal. How would I fix it? Thanks
Old 05-05-2013, 08:10 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
search:
Permatex 27828 Body Shop Heavy Duty Headliner and Carpet Adhesive
Old 05-05-2013, 09:39 AM
dixie460's Avatar
dixie460
dixie460 is offline
I took mine out. Ripped all the cloth off of it, then set it out in the grass and used an angle grinder with wire wheel to remove the foam/adhesive. If you do this, all it takes is a kiss from the wire wheel, don't let it dig in because the backing is just cheap cardboard.
I still have to reinstall it. Think I'm going to find a black vinyl tablecloth of suitable quality and use that for a headliner. It'll look good and if anything gets splashed up there (mud) it'll wipe right off.
Old 05-05-2013, 03:45 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I just did the headliner in my bronco
I very carefully pealed off the old fabric and left behind the foam.
then, went to Joanne fabrics and got 1.3 yards of new material and a Large spray can of spray adhesive(for foam and cloth). Had the new fabric on and trimmed in 20 Min and for less than $20
Old 05-05-2013, 04:35 PM
kowboy1's Avatar
kowboy1
kowboy1 is offline
Did you take pictures?
Old 05-05-2013, 07:27 PM
BiGGreen350's Avatar
BiGGreen350
BiGGreen350 is offline
here are some pics of mine.
old headliner pealed off and foam removed, i wasnt lucky enough for the foam to come off with the fabric, so i removed the remaining foam with flap wheel(outside, will make a mess) on a drill
the layed my new fabric out and used the adhesive
then trimmed it up and installed, really basic stuff
Old 05-06-2013, 04:36 AM
Diesel_Brad
Matt. Did you use fabric with the foam on it, or did you just glue the new fabric to the cardboard?
My headliner
Old 05-06-2013, 02:11 PM
BiGGreen350
fabric with foam. just went to my local upholstry shop. they have alot of boat vinyls and auto stuff. just gave em my interior sample from old headliner and tole em i was redoing my headliner. they got me the material and also gave me adhesive. i paid right around mid 20s to do mine also, really simple stuff.
here i took a couple pics of the fabric i used, still had a few scraps around
Old 05-10-2013, 07:16 PM
1997fordf350
How much would a used one cost at a junk yard?
Old 05-11-2013, 06:32 AM
Diesel_Brad
IF you can find a good used one, $10 - $100
Old 05-12-2013, 05:22 PM
AdrianJR's Avatar
AdrianJR
AdrianJR is offline
Guys - I need ideas on what to do if the head liner was never there from the factory. I'm toying with either sticking cheap carpet straight to the metal or (for better insulation) fabricating something with a very thin sheet of plywood (not sure how).
What do you think? The junk yard option isn't practical up here in Nova Scotia.
Old 05-12-2013, 06:17 PM
SouthernBlues's Avatar
SouthernBlues
SouthernBlues is offline
I replaced mine with a flag
Old 05-12-2013, 07:37 PM
Diesel_Brad
No junk yards? How about someone parting a truck on craigslist? It dont have to be the right color.
As for doing the plywood thing, NO. Same goes for gluing the fabric to the metal
SouthernBlues that looks worse than the most sagging headliner I have ever seen
Old 05-12-2013, 07:39 PM
mr.fordneck's Avatar
mr.fordneck
mr.fordneck is offline
Honestly I got a mint replacement from the wreckers for 15 bucks
Old 05-12-2013, 09:42 PM
eagle275's Avatar
eagle275
eagle275 is offline
LMC Truck parts,NPD,etc.
Quick Reply: Headliner
