May BS Thread
#151
#153
#154
On the topic of the I-5 bridge, I have only heard/read that it collapse with people on it. The City inspector said they didn't know when the last time they were inspected and that the bridges around there are all old.
#155
someone just sent me this link about it I-5 bridge collapses over Skagit River near Mount Vernon; cars in river - Local - MyNorthwest.com
#156
#157
#159
From what I have been able to gather the truck was about to cross the bridge straddling the lanes but another semi came up on his left and prevented him from moving left. And from what I see of a damage and accounts of the trucks impact with the bridge. The load clipped the top right corner but that's not what damaged the bridge. That impact turned the truck to the right slamming it into a the barrier which it climbed and slammed into the side structure of the bridge.
Look at this pic, the cross beam that everyone points at him hitting is rather undamaged but the first vertical I-beam is sheared off right at the top of the barrier. With the beam pushed against the next beam. The next few are underwater but what would be the 5th beam struck you can clearly see with a almost 90 deg bend in it where it was hit.
Just my theory but the truck it seams basically took out the 2nd thru 6th vertical and 45 deg I-beams of the bridge.
#160
There are six horizontal overhead beams to each section of the bridge.
I'd say he took out only the third and maybe fourth verticals, and hit the second overhead. I believe he may have actually missed the initial overhead beam, as it looks pretty intact.
At any rate, this should be REAL easy for the NTSB to re-construct.
Pop
Pop
#161
Well that collapse is causing traffic nightmares. I was up in Burlington this afternoon picking up a car, and I was stuck in between two lights for about 20 minutes
Well on the plus side, I picked up myself a Baja bug! Go check it out
TheSamba.com :: View topic - Summer Project Car
#163
#164
Found a photo of the truck and the load at this link.
Not much damage that I see.
Here is a good set of photos.
'Horrified' trucker watches I-5 bridge collapse behind him | Local & Regional | Seattle News, Weather, Sports, Breaking News | KOMO News
This is a link to the main page with some video.
Sean
Sean
#165
