66 F100 2WD Custom Cab short box, frame off build.
Old 06-02-2013, 12:34 AM
SixtySix Ford's Avatar
SixtySix Ford
SixtySix Ford is offline
damn! Nice work! when can I bring mine over? are you going to leave the stock suspension?...sorry if I missed that part!
  #32
Old 06-02-2013, 09:11 AM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
Looking pretty damn good!!!
  #33
Old 06-02-2013, 09:46 PM
cookster351's Avatar
cookster351
cookster351 is offline
Thanks guys!
For suspension I have a disk brake/pwr steering setup I'm going to install. Haven't done that yet. Gonna get aftermarket springs and lower the front about an inch.
  #34
Old 06-02-2013, 10:01 PM
cookster351
Got the kick panel piece welded in.
Had to open up the pillar to weld the rear hinge bolt plate. The retainer had rotted away and broke. While I was there I made a angle brace to replace the vertical pillar piece that rusted away.
Welded it up.
Now all I have to do is make the piece for the bottom of the pillar, then weld the piece I cut out back in...
  #35
Old 06-02-2013, 10:39 PM
schoo's Avatar
schoo
schoo is offline
I did the same thing but only cut three sides and bent it back
That was about October today I started up the engine for the first time in 3 years. It been a lot of fun, hope your having good times also
Roy
  #36
Old 06-02-2013, 10:56 PM
cookster351
Roy, yep I'm enjoying working on the truck. I took about 15 yrs off from working on cars. Family, school, work, all the reasons everyone else has.
Everyone has their own "therapy", working on old vehicles is mine.
As far as cutting out 3 sides of a piece and bending the remaining side back, yes that's an option and I did think of that. The problem with that though is the bent side will get a buckle in it that has to be hammered back out. This area doesn't show so that really wouldn't matter. Not saying your method is wrong, it sure is easier! I just decided to do it this way...
Enjoy your truck!
  #37
Old 03-06-2014, 08:45 PM
cookster351
Well guys I've been away since last summer, sorry I haven't posted in so long. I'm finally back to working on my truck again.
Here's a few pics I took last year and never posted.
Here's the cowl drain area repair welded back up and ground down.
Driver's side floor pan cut out. I sand blasted around the cutout. I will sandblast everything after I get all the welding done and ground down.
The floor pan being trimmed and fit. It's all welded now, I need to take some more pics and post along with my current progress.
  #38
Old 03-06-2014, 10:02 PM
TxStang2010's Avatar
TxStang2010
TxStang2010 is offline
great work so far !
  #39
Old 03-07-2014, 10:09 AM
C G B's Avatar
C G B
C G B is offline
Always cool to see the progression on a project.
Mine has been back burnered since last summer as well so I know how that goes.
  #40
Old 03-07-2014, 06:07 PM
missinfishin10's Avatar
missinfishin10
missinfishin10 is offline
Very nice work!
  #41
Old 03-07-2014, 06:36 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
Looks real nice.
I am envious of your abilities.
  #42
Old 03-08-2014, 03:33 PM
1964FORDTUF's Avatar
1964FORDTUF
1964FORDTUF is offline
Originally Posted by schoo
Good luck on project.
To bad your in ga have a hood in Cali and a few other 65' parts
What else do you have and is your hood really top notch condition??
Thanks...
  #43
Old 03-31-2014, 10:01 PM
cookster351
Hi guys, been away again for a bit, life does sometimes get in the way. Lost both my parents 2 weeks ago. They had been sick so it was expected. Anyway, working on Effie does make great therapy...
64Ford, I have a hood I bought at last years F100 supernats. It's in very good shape. Also bought a correct year tailgate and nice 66 core support. Expensive but worth it. Paid $400 for the tailgate and $300 for the core support. There was a guy there selling a Cherry 66 support for $600, but I passed on that one. Those things are like gold for sure! Not sure if I mentioned it earlier but I also found a guy that had 3 nice 66 battery trays, so I bought 2. Also got the pwr steering column firewall bracket. Paid $60 for that, again hard to find.
  #44
Old 03-31-2014, 10:34 PM
cookster351
Few pics of where I'm at now.
FINALLY got my rotisserie finished (minus some more red paint). Could'a bought one but wanted to build a custom version that bolts to the door pillars. I wanted this so I had full access to the floor pan. Once I finish the pan I will build the legs that mount to the body mounts as in all the other rotisseries out there.
<a href="https://www.flickr.com/photos/95792329@N03/13551600265" title="IMG_1286 by Wes Cook, on Flickr"><img src="https://farm8.staticflickr.com/7355/13551600265_2b1cf930ac.jpg" width="500" height="375" alt="IMG_1286"></a>
<a href="https://www.flickr.com/photos/95792329@N03/13551600415" title="IMG_1287 by Wes Cook, on Flickr"><img src="https://farm4.staticflickr.com/3773/13551600415_c0060159bb.jpg" width="500" height="375" alt="IMG_1287"></a>
Got the floor pan section seam welded up and ground down.
<a href="https://www.flickr.com/photos/95792329@N03/13551611965" title="IMG_1289 by Wes Cook, on Flickr"><img src="https://farm8.staticflickr.com/7296/13551611965_d540c67472.jpg" width="500" height="375" alt="IMG_1289"></a>
<a href="https://www.flickr.com/photos/95792329@N03/13551715123" title="IMG_1292 by Wes Cook, on Flickr"><img src="https://farm4.staticflickr.com/3731/13551715123_6f53235edf.jpg" width="500" height="375" alt="IMG_1292"></a>
I'm not that happy with overlapping the floor pan section but it's done so oh well... Since I have the rotisserie now I'm pretty sure I'm gonna but weld the passenger section since now I can easily work from the bottom.
Probably gonna do some sandblasting next before it gets so hot here in Ga.
  #45
Old 04-01-2014, 10:34 PM
TEX001's Avatar
TEX001
TEX001 is offline
You sure look like you've done this before, is this your first frame off or do you have "notches" from past builds? Looking good.
Quick Reply: 66 F100 2WD Custom Cab short box, frame off build.
