brake pedal travel still long
Alright still haven't been able to figure out my trucks brake issue still have a pedal that travels 3/4 the way to the floor before it works I've bled the brakes a million times no air bubbles new master cylinder by the previous owner and I just replaced the brake booster and adjusted the rear brakes but still the same pedal travel anyone have anything else to try before I send it off to a shop???
1988 was the first year for ABS. You have rear ABS. You'll find the unit on the frame under the cab floorboard on the drivers side. Try bleeding the ABS unit. You can also try removing the spring from the ABS unit, sometimes they cause issues. If that made your brakes stiffer, you'd know you need a new ABS unit.
Also, replace your rubber brake hoses. If they're old, they'll "balloon" with the pressure before actually get much fluid pressure to the brakes.
Is the brake pedal stiff if the parking brake is on (suggesting the rear brakes still aren't adjusted tight enough)? Is the parking brake easy to push to the floor?
Are you sure that your brakes (shoes/drums & pads/rotors) aren't just plain worn down? Usually you adjust rear drums up to get something out of them...
Good luck!
Good luck!
Received 3,108 Likes
on
Re-adjusted the push rod length no change.
Parking brake is hard to push to in and doesn't go to the floor. And doesn't effect the brake pedal when the parking brake is on
All the pads and shoes looked good to me and the hoses were replaced by the old owner
Still going to try to bleed the abs unit and see if that has any effect
Yeah, see if you can do any good by doing that. Like I said, you can try taking that spring out too. I've known several similar cases where the ABS unit was the whole issue...
You can take the end piece of the ABS unit off and pull out a spring. That'll basically disable ABS making the ABS unit more of a fluid hub. I'll try to take a pic of my ABS unit later and post it if I get a chance.
I know of some people that have taken the spring out and just left it that way. Nothing really wrong with doing that, just be more careful. I know the rear anti-lock is helpful since the rear of the truck doesn't weigh all that much empty.
