New Fuel Tanks
Old 04-25-2013, 03:27 PM
Arps 6.9's Avatar
Arps 6.9
Arps 6.9 is offline
New Fuel Tanks
Would anyone be interested in fuel tanks, I am gonna make a new aluminium one for the back tank, I'm thinking 26 or so gallons with a fuel sump in the bottom, with a return in the top, and I am planning on using a universal fuel sender. This will let me delete my front tank, and fuel selector valve. Not sure on costs or anything yet, gonna try to keep it lower, and the tank will set in the stock location, and use a different filler neck, my main point in doing this is so if and when if fails in the future, it will be easily fixable. Austin. I'll post up some pictures of install and everything else when I get to getting it done, just seeing what I should order.
Old 04-25-2013, 05:01 PM
genscripter's Avatar
genscripter
genscripter is offline
If i could make a suggestion, use a Centroid fuel level sending unit. they don't have any moving parts and I've never had one fail, on any of my cars.
Old 04-25-2013, 08:20 PM
Kleenax's Avatar
Kleenax
Kleenax is offline
New fuel tank
I'm interested, but I'm looking for something like 35 gals for a rear tank. I like the use of aluminum, and a universal sending unit.
If you are interested in getting some orders, I would strongly consider something larger than 26 gal. I would only be interested if it was something at or greater than 35 gal.
Old 04-25-2013, 08:21 PM
Arps 6.9's Avatar
Arps 6.9
Arps 6.9 is offline
Thank you, I was looking and I seen a lot of units that were for marine use, and was planning on using one of those, I'll check out those units you recommended because I couldn't seem to find a very sturdy looking sender.
Old 04-25-2013, 11:19 PM
Arps 6.9's Avatar
Arps 6.9
Arps 6.9 is offline
I would just make it deeper it wouldnt be a huge problem, it will be a couple weeks as the concrete in my shop gets poured Saturday, and it takes a week to cure, and with my build the fuel tank isn't highest priority, although I would like to do the entire fuel system on one shot, I will keep you posted.
Old 04-26-2013, 12:35 AM
Red454sedgwick's Avatar
Red454sedgwick
Red454sedgwick is offline
lmc sell a 38 gallon tank. I've put them in both of my idis
Old 04-26-2013, 07:25 AM
Arps 6.9's Avatar
Arps 6.9
Arps 6.9 is offline
I saw they had the tanks, what did you do for a sender, if I can remember right, it was expensive.
Old 04-26-2013, 11:05 AM
Red454sedgwick
You extend the stock sender, there around 200 bucks. I would bet that you wrap up more than that in building your own tank. Remember that you time is free to you, but still worth something.
Old 04-26-2013, 07:44 PM
Kleenax's Avatar
Kleenax
Kleenax is offline
LMC large-capacity fuel tanks
Since they don't mention in their catalog whether or not you can use these tanks with diesel, I called LMC directly and asked them if they were galvanized and/or good for use with diesel, and they told me NO, they are NOT OK to use with diesel fuel. Did they say anything about that when you ordered them?
Old 04-26-2013, 07:49 PM
airdale94's Avatar
airdale94
airdale94 is offline
Just got a new sender from LMC, $100. Will keep an eye on this thread as I might be interested in a tank.
Old 04-26-2013, 09:34 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
I was wondering about that when I saw those, glad to hear someone checked up on 'em.
Not that I'd enjoy filling a 38 gallon tank! $150 fill up, ouch, ouch....
Old 04-26-2013, 11:27 PM
Red454sedgwick
No, but I didn't ask. I knew that they would work, maynot be right but still work.
I modified the one that is in my 93 to make the sending unit work, it's been in for over a year and still is working.
Old 04-28-2013, 07:35 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
The tanks are probably ni-terne coated, not galvanized. Most people mistake this and just think its galvanized.
LMC probably says it doesn't fit, because they senders are different, and the holes in the tanks have tabs in difference spots gas vs diesel.
Its nothing a grinder and a few seconds won't fix.
Old 04-28-2013, 08:48 PM
Kleenax's Avatar
Kleenax
Kleenax is offline
I didn't make any mistakes or assumptions here..........
When I called LMC and asked them about the larger fuel tanks, they didn't say it wouldn't fit, they said specifically that it was NOT for use with diesel fuel. And I would have also purchased the sender that they specify for this tank, as they also offer this along with the tank (if it was approved/mfr'd for use with diesel).
Old 04-28-2013, 09:23 PM
Red454sedgwick
my 87 the sender fit in the tabs,
the 93 i had to move the notches
you have to extend the stock sending unit, you don't have buy a new sending unit
Quick Reply: New Fuel Tanks
