3G Alternator How-To
As far as a write up I never found a good that really covered everything but the one linked below covers ALOT and has links to other forums to cover what is not covered in it.
https://www.ford-trucks.com/forums/1...doing-one.html
There are many threads about the 3G upgrade.
Some are stickied in the tech headings both here and the '80-'86 sub forum.
If you look on the back of your alternator you will see one of the regulator screws says "Ground Here to Test".
That will send your alternator to full output.
Otherwise, just check the voltage at idle and something like 3,000 rpm.
Then check with all the lights, fans etc.. on.
External fan = 2G, but anyway, there is no possible way you have a 2G in there stock, in 1996 they're all 3G. You just need to take some care of your alternator, replace the brushes, they're mounted on the regulator, also check the slip rings, those are the copper rings the brushes rub against, they're mounted on the stator (if you don't know about alts. get a diagram and all will make sense). Those are the usual wear items, don't run the truck like this because you risk burning the regulator, and that one is expensive (if the brushes and rings look good then it's probably the cause). If all the afore mentioned checks, then the rectifier is the next part to check.
You can determine if you have a 95A or a 130A unit easily: look at the face that houses the pulley, if there are 3 groups of 4 holes (spread 120° from each other) you have a 95A small case, if the groups are of 2 holes then congrats, you got a 130A large case.
on
If you ground the screw to full field the alternator and your voltge goes up, thet tells you the regulator is bad.... are you really gonna just replace the regulator? If you are only getting 9v running, its not charging, 99.9% of the time a new alternator will fix it. I'd just replace it, then if it still doesn't charge (.1% chance) check the wiring.
If you want to try to full field it, on the back of the alt, the black plastic thing is the regulator. I think there are 4 small torx bolts that attach it to the alt. The one that looks difffernt is the one you ground to full field the alt.
If your at 9.5 volts your alternator is in need of replacement. It should be around 14 give or take a little for load.
Unfortunately I don't remember the exact differences but maybe this will get you started looking in the right area...
