67 f100 electronic ignition ?
i just replaced mi points with the accel 2020 electronic ignition kit. the truck wasnt running before but it was a point issue. now that i have the elec. ig. installed it will only fire when i disingage the starter. no fire until i let go of the switch.
any help would be great. Thanks
See if you have spark at the plug while someone turn it over while your grounding it if it does look and see if it a good blue spark or week orange/yellow spark. Also in some of the wiring diagrams there. Happens to be 2 wires one of them was a Pink wire it had a resistor in line on it that when you go to a electronic ignition you tossed that resistor. BUT on my 68 I could never find that Pink wire and I tossed the point system for a DURAspark system So it sounds like your getting half the voltage you need for start then once you get it turning over go you let go of the key and it still has the momentum the switch comes back to run and shoots the full voltage and starts up.
I didn't disconnect anything but points. It's a simple kit too install
Try checking the starter solenoid. I'll check my wiring schematics when I get home. I believe when the ignition switch is turned to "start" it sends 12v to the solenoid at the "s" terminal. When this happens the solenoid sends power to the starter AND sends the 12v to the coils via the "I" terminal.
ill give it a shot soon as i get another person available to trun the switch for me. thanks for the info.
this is driving me crazy
OK, i think im following you now. ill check my voltage at the selonoid tomorrow. i quit for today.
Not voltage regulator. That would be possible only if the engine was running spinning the alternator. I hope someone else chimes in here that knows more than me but I think it is alright. I am thinking the 2 volts your truck lost there is just parasitic loss. Power going around the Grand Canyon before reaching the coil. With only the battery to push it and no alternator back-up. I wouldn't worry about it until that Bad Boy is running and then there is only 9 - 10 at the coil.
